My cultus VXR 2007 has a problem. Its acceleration has droped considerably. While driving the RPM rises but the car isn't accelerating the way it should. What should be the issue?
chk tht whether the sound of de engine increase wid the rpm or not!it happened with my vxr tht the rpm meter got maniac...after 3k rpm it started rising like hell!:S
yup the sound is like i am torturing the engine
bro your clutch plates are gone change my friend had the same problem high rpm but no accelaration!he changed the clutch plates the problem was gone!
yup, for sure it's the clutch & pressure plate.
@ poster prob solved!
problem is in the Clutch . it is worn out. change it and u would be fine
hey bro its ur clutch thats gone wrong chamge it soon or u will be standing at the side of the road.I had the same issue with my car
thanks people would get it done.
@zuhairanwar
i believe dats da second time u will change clutch plate of ur cultus 07.....??
chk the clutch plate
thats coz of independence day adventures ;(
You must have driven it in deep water during the rains.... ur clutch and pressure plates are shot... need to replace them...
kya kia tha?
Guys1 most of you got it wrong. There was some problem with the axle. Got it Fixed. @Umer (tyrant_heart) Man this time is wasn't my fault. Wesay bhi drifting ka itna mauka kahan mila
Cultus pe drift
@hassan44 Kyun? what do you think cultus is?
yup its the clutch plate same happened to my rx8rpm was very high but the car was bearly moving
No, wasn't the cluch plate because I didn't mention that the car was barely moving. It was moving but with slightly more effort than before
If dat would b a clutch prob ul not feel any jirk while gear shifting ur car will run like a prosmatic.
