The 1st generation 4E-FE was the basis of the 4E-FTE, appearing in 1989, which was a turbocharged engine producing 135 hp (101 kW) at 6400 rpm with 116 ft·lbf (157 N·m) of torque at 4800 rpm. The 4E-FTE was the most powerful of the E series engines ever produced. It was produced exclusively for the Toyota Starlet GT Turbo (Japan Only) and its replacement, the Toyota Glanza V (Japan only). However the 4E-FTE was a very popular conversion engine by enthusiasts for many small Toyota cars such as the Corolla, Tercel and Paseo, which it fitted into with standard Toyota parts. The 4E-FTE differed internally from the 4E-FE only by its stronger connecting rods, lower compression pistons and different head gasket. It also features a harmonic damper instead of a normal crankshaft pulley. The turbocharger fitted to the 4E-FTE was Toyota's own CT9 model which featured an internal waste gate and had 2 modes; low (0.4 bar/40 kPa) and high (0.65 bar/65 kPa) boost. The low boost mode was electronically controlled by a solenoid valve and the ECU and the overall or high boost was controlled by the actuator connected to the turbocharger. The 4E-FTE also had a "Top mounted", air cooled, Intercooler. The 4E-FTE was mated to the Toyota C52 transmission (EP82 Starlet GT) and the C56 transmission (EP91 Glanza V). Although aftermarket parts could substantially increase the power output of the engine, the major limitation is the fuel injection system.
- Specs:
- 74 mm Bore
- 77.4 mm Stroke
- 8.2:1 Compression Ratio
