no yaar, after several visits ,one day @ 4th gear car suddenly stops, no signal on cng switch at all
i took to roadside mech. & he check some fuse & wire actually open the fuse from left side under dashboard, after that it becomes better start,i gave him 400 but new problem starts, the fan stops working, then he told that ur fan motor seems faulty, i became angry that it was ok before but he insist that u hav to install relay & make ur fine direct,then it will run ,it cost 800 or another option go factory & buy "automatic" in 3500
then i went from there in angry mood( at last he advise ur temp. is v. hi & fan not working so may blew gaskit) but i dont heard to him
& rushed my car to another footpath mech. & told him story, he open the fuse (from left side under dashboard) & cut fuse from here,rejoin cutted wire & come to right driving side , open cng switch ,open its wire & there was red wire , he cuts wire from one point & join that old fuse( which he took from left side) in between this wire, after that fan starts working
in all these exercise, after that i experience that situation becomes 70-80% better than before( i cannot say 100% bcoz sometime cause same problem)
if it will come again then i will install l.r advancer
