Salam everyone. Recently I bought a 4G93 SOHC and planning to convert into DOHC with Mivec head. As 4G92 Mivec DOHC and 4G93/4G93T SOHC/DOHC share same bore size so conversion here in Malaysia is common. But this project is held in Karachi, Pakistan. I will be using Wiseco Turbo Pistons 81.50MM 0.5MM oversized, Duratech Conrods, ACL Race bearings and turbo not decided as yet. What parts will be replaced in this conversion any idea ? I will be using 4G92 DOHC Mivec Head, 4G92 Mivec wiring, sensors and ecu. 4G93 Block, pistons, conrods, bearings and head gaskit of 4G93T most probably 2.0MM. What else will I be needing ? I have a confusion in my mind which water should I use ? 4G93 or 4G92 DOHC pump ?
