Specifications and Approvals Mobil 1 5W30
<TABLE dir=ltr border=0 cellSpacing=0 cellPadding=0 width=624><TBODY><TR><TD vAlign=center width="50%">Mobil 1 5W-30 meets or exceeds the requirements of:
</TD><TD vAlign=center width="50%"> </TD></TR><TR><TD vAlign=center width="50%">ACEA
</TD><TD vAlign=center width="50%">A1/B1, A5/B5
</TD></TR><TR><TD vAlign=center width="50%">API
</TD><TD vAlign=center width="50%">SN, SM, SL,SJ
</TD></TR><TR><TD vAlign=center width="50%">ILSAC
</TD><TD vAlign=center width="50%">GF-5
</TD></TR><TR><TD vAlign=center width="50%">Ford
</TD><TD vAlign=center width="50%">WSS-M2C946-A
</TD></TR></TBODY></TABLE>
Typical Properties
</TD><TD vAlign=center width="50%"> </TD></TR><TR><TD vAlign=center width="50%">SAE Grade
</TD><TD vAlign=center width="50%">5W-30
</TD></TR><TR><TD vAlign=center width="50%">Viscosity @ 100ÂșC, cSt (ASTM D445)
</TD><TD vAlign=center width="50%">11.0
</TD></TR><TR><TD vAlign=center width="50%">Viscosity, @ 40ÂșC, cSt (ASTM D445)
</TD><TD vAlign=center width="50%">61.7
</TD></TR><TR><TD vAlign=center width="50%">Viscosity Index
</TD><TD vAlign=center width="50%">172
</TD></TR><TR><TD vAlign=center width="50%">Sulfated Ash, wt% (ASTM D874)
</TD><TD vAlign=center width="50%">0.8
</TD></TR><TR><TD vAlign=center width="50%">HTHS Viscosity, mPaâąs @ 150ÂșC (ASTM D4683)
</TD><TD vAlign=center width="50%">3.1
</TD></TR><TR><TD vAlign=center width="50%">Pour Point, ÂșC (ASTM D97)
</TD><TD vAlign=center width="50%">-42
</TD></TR><TR><TD vAlign=center width="50%">Flash Point, ÂșC (ASTM D92)
</TD><TD vAlign=center width="50%">230
</TD></TR><TR><TD vAlign=center width="50%">Density @15.6 ÂșC, mg/l (ASTM D4052)
</TD><TD vAlign=center width="50%">0.855
Specifications and Approvals Mobil 1000 (10w40/15w40/20w50)
<TABLE dir=ltr border=0 cellSpacing=0 cellPadding=0 width=624><TBODY><TR><TD vAlign=center width="40%">Mobil Super 1000 X1 meets or exceeds the requirements of:
</TD><TD vAlign=center width="20%">10W-40
</TD><TD vAlign=center width="20%">15W-40
</TD><TD vAlign=center width="20%">20W-50
</TD></TR><TR><TD vAlign=center width="40%">API SL/SJ
</TD><TD vAlign=center width="20%">X
</TD></TR><TR><TD vAlign=center width="40%">ACEA A3/B3
</TD></TR></TBODY></TABLE><TABLE dir=ltr border=0 cellSpacing=0 cellPadding=0 width=624><TBODY><TR><TD vAlign=center width="40%">Mobil Super 1000 X1 is recommended by ExxonMobil for use in applications requiring:
</TD></TR><TR><TD vAlign=center width="40%">API CF
Typical Properties
<TABLE dir=ltr border=0 cellSpacing=0 cellPadding=0 width=624><TBODY><TR><TD vAlign=center width="40%">Mobil Super 1000 X1 10W-40
</TD></TR><TR><TD vAlign=center width="40%">Viscosity, ASTM D 445
</TD><TD vAlign=center width="20%"> </TD><TD vAlign=center width="20%"> </TD><TD vAlign=center width="20%"> </TD></TR><TR><TD vAlign=center width="40%">cSt @ 40Âș C
</TD><TD vAlign=center width="20%">97
</TD><TD vAlign=center width="20%">107
</TD><TD vAlign=center width="20%">162
</TD></TR><TR><TD vAlign=center width="40%">cSt @ 100Âș C
</TD><TD vAlign=center width="20%">14.4
</TD><TD vAlign=center width="20%">18.7
</TD></TR><TR><TD vAlign=center width="40%">Sulfated Ash, wt%, ASTM D 874
</TD><TD vAlign=center width="20%">0.91
</TD><TD vAlign=center width="20%">0.93
</TD></TR><TR><TD vAlign=center width="40%">Phosphorous
</TD><TD vAlign=center width="20%">0.144
</TD><TD vAlign=center width="20%">0.147
</TD></TR><TR><TD vAlign=center width="40%">Flash Point, ÂșC, ASTM D 92
</TD><TD vAlign=center width="20%">230
</TD><TD vAlign=center width="20%">233
</TD></TR><TR><TD vAlign=center width="40%">Density @15Âș C kg/l, ASTM D 4052
</TD><TD vAlign=center width="20%">0.87
</TD><TD vAlign=center width="20%">0.89
</TD></TR><TR><TD vAlign=center width="40%">Pour Point, ÂșC, ASTM D 97
</TD><TD vAlign=center width="20%">-30
Specifications and Approvals Mobil 1 5W-50
<TABLE dir=ltr border=0 cellSpacing=0 cellPadding=0 width=624><TBODY><TR><TD vAlign=center width="50%">Mobil 1 5W-50 meets or exceeds the requirements of:
</TD><TD vAlign=center width="50%">5W-50
</TD></TR><TR><TD vAlign=center width="50%">API SN,SM/SL/SJ
</TD><TD vAlign=center width="50%">X
</TD></TR><TR><TD vAlign=center width="50%">ACEA A3/B3, A3/B4
Typical Properties
</TD><TD vAlign=center width="50%">Value
</TD></TR><TR><TD vAlign=center width="50%">Viscosity, cSt ASTM D445
</TD><TD vAlign=center width="50%"> </TD></TR><TR><TD vAlign=center width="50%">@ 40Âș C
</TD><TD vAlign=center width="50%">108
</TD></TR><TR><TD vAlign=center width="50%">@ 100Âș C
</TD><TD vAlign=center width="50%">17.5
</TD><TD vAlign=center width="50%">180
</TD><TD vAlign=center width="50%">1.3
</TD></TR><TR><TD vAlign=center width="50%">Phosphorous, wt% (ASTM D4951)
</TD><TD vAlign=center width="50%">0.1
</TD><TD vAlign=center width="50%">231
</TD></TR><TR><TD vAlign=center width="50%">Density @15.6 ÂșC g/ml, (ASTM D4052)
</TD></TR><TR><TD vAlign=center width="50%">Total Base Number (ASTM D2896)
</TD><TD vAlign=center width="50%">11.8
</TD></TR><TR><TD vAlign=center width="50%">MRV at -35 ÂșC, cP (ASTM D4684)
</TD><TD vAlign=center width="50%">29,244
</TD></TR><TR><TD vAlign=center width="50%">HTHS Viscosity, mPaâąs @ 150 ÂșC (ASTM D4683)
</TD><TD vAlign=center width="50%">4.4
PERFORMANCE STANDARDS of Caltex Havoline10w30 Singapore
âą API SL
âą API SJ, SH, SG, SF
âą API CF
KEY PROPERTIES
SAE Grade 10W-30
Density at 15°C, kg/L 0.877
Base Number, D2896, mg KOH/g 8.1
Base Number, D4739, mg KOH/g 7.9
Flash Point, °C 210
Phosphorus, %m 0.10
Sulfated Ash, %m 0.94
Viscosity, cSt at 40°C 77.9
Viscosity, cSt at 100°C 12
Viscosity Index 149
Zinc, %m 0.11
The peromin Ultra 7 standards are quite good too, here is the prformance of ultra 7..
Note: the performance standards have been chosen from foreign countries sites, dont know if the same performance standars exist here..
