Thats the purpose of fuse - it should blow if current exceed 7.5 Ampere in your case.
There must be something wrong - you need proper investigation to find out the actual reason of high load on it.
A CNG electrician can fix the issue with in 15 minutes - might be by putting some relay to resist the amount of current.
