Hello Friends,
I have a 2001 automatic vti.. old shape. The problem here is that if I have to put my car in P or R the gear knob or that button used to put it to that mode becomes as hard as it can be...
I recently had my transmission oil changed... can anyone tell me what can be the problem?
remove the shift lever cover and clean out the lock button mechanism, it must be loaded with dead skin, dirt and lustre, armor all residue.
The transmission fluid has nothing to do with it.
It works well when in reverse gear, only putting it in P or R is giving trouble.. can anyone suggest on what to do? If the car is in P or R it works like a charm
Hv u cosulted a Honda Mechanic about it
better do as Xulfiqar instructed.The gear of my vitzy use to get harder as soon as i cleaned the inner mechanism its as soft as ever.Otherwise it can be gear cable can see tht aswell.Its 6th gen civic right?
its a 2000 model.. how much karcha would be of cable?
a new cable would cost between Rs 4500/- to Rs 6000/-, disconnect the cable from the shifter, if still hard, you need to take the shiftbox out from the car and clean/lube it.
^^^^^^^+1
