you have already read my last post so i am rewriting part of it with addition
Maintanance:-
timing belt 40000km
front suspension around 80000km-100000km(Depending On driving Conditions)
Every 10000km sensor checkup+tuning(A small computer attached to vehicle available in work shop does that)
Spark plugs 15000km-20000km (Depends on driving conditions)
Air filter 10000km(Clean It Weekly for best feul economy performance)
Feul Filter 15000km-20000km(Depending on type and quality of feul)
Brake Service 10000km esp rear brakes
(Relacement if original around 25000km-30000km)If driven on normal road......steep hills driving usually decreases life of brakes
Note:- when climbing down hill daewoo will tend to accelerate.try keeping car in low gears as when coming down fron peer sohawa use first gear and dont accelerate-other cars will overtake you but this is only issue in daewoo that it tends to accelerate when in gears above 1st(Plus point when racing the car on roads i.e excellent engine response)
IAC Valve service 10000km
feul pump checkup 70000km
feul injector checkup/replacement 100000km
Distributor parts service/Replacement 80000km
Oil Filter(Original)--- 10000km
oil(caltex Havoline)--- 5000km
Coonect Cutouts to both head lights to avoid damage to dipper switch
Connect cutout to A/C Clutch(To avoid Compressor Burnout)
Place Extra Fan with cutout for A/C(Enhances engine/ compressor cooling and improves efficiency of A/C working)
For complete overall exterior and interior around 80000-130000 depending on features you select
FEDERAL AUTOS I-10 ISLAMABAD ph.no:-4440508, 4443594
If you Buy a worst condition car then you should change everything--Mechanical + Electrical but keep engine same as parts are easily available
Buying a Good Condition Car is also better option but will cos you around 2,80000 to 320000 for kint condition car and around 325000 - 400000 for excellently maintained car
if you acquire first option then replace every thing thoroughly--confirm that chassis has never been tempered..not a major accident vehicle..the vehicle has not been corrected by a second chassis put together to first one..Prefer petrol driven car
Shahzad Available on the above no can help you get a vehicle
