MAIN PARAMETERS
Engine volume, cc 658
Frame name GBD-HA24V
SIZE
Exterior length, mm 3395
Exterior width, mm 1475
Exterior height, mm 1500
Exterior size (L x W x H), mm 3395x1475x1500(mm)
Interior size (L x W x H), mm -x-x-(mm)
Wheel base, mm 2360
Front axle length, mm 1295
Rear axle length, mm 1290
Clearance, mm 150
Mass, kg 720
Capacity 4
Doors 5
Turning radius, m 4.1
Fuel tank capacity, 30
Seat rows 2
Front/rear axis length 1295/1290(mm)
ENGINE
Engine name K6A
Max power, hp 54
Max power RPM, rpm 6500
Max power, hp (kWt) / rpm 54(40)/6500
Max torque, kg*m 6.2
Max torque RPM, rpm 4000
Max torque, kg*m (N*m) / rpm 6.2(61)/4000
Engine type 3 cylinder DOHC
Fuel Regular gasoline
Fuel consumption (10/15 mode), l/100km 4.3
Variable cylinder system
Eco type 2005 emission regulation 75% reduction
SUSPENSION
Front brake disk
Rear brake drum
Front suspension strut
Rear suspension isolated trailing link type
Front wheels 135/80R12
Rear wheels 135/80R12
