I have Suzuki Mehran 2007 on petrol only. I recently visited Suzuki IG Motors where free inspection was going on by PakSuzuki. They checked my car and identified following problems:
- Gas Low cooling. Service required.
- Balance rod bush change
- Gear lever kit change
- Rear side bearing noise
- Axle boot change
- Air blow pipe damaged
- Break Service
- Tapitt Cover Packing change
- Tapitt Noise Adjustment
- Light Change
- Parking Light Change
- Back light change - Room light
The charges they told me are around 15k. I confirmed parts rate from same dealer and it is around 11K. Please suggest if it is a good idea to go for it. Or should i skip some things from above things. May be they are just trying to make money by identifying unnecessary issues.
One thing i wanna tell you that there is wheel bearing sound i can listen, there is vibration, my car 1st and 2nd gear stuck usually when car is idle...AC cooling is just ok...car give problem in picking first and second gear...
