Dear @xulfiqar bahi,
Iam in search of a good mechanic in karachi
I own a suzuki Banleno, and it has got problems since the day i bought it. I have spent big amount due to my mechanic, who always try to fool around. iam now searching for a good mechanic who can handle these issue of an EFI car.
Current issues:
1) Car gives knocking sound on petrol, check engine light turns on at petrol and went off as soon as CNG kinks-in, rpm on petrol is not stable and car is not running on low rpm below 1.5 and gives high knocking sound. (for this problem my mechanic has repaired the throttle which he said was damaged, serviced fuel injectors, however none of them solved the problem. He is now thinking to replace the injectors, he said fuel pump seems fine as the fuel pressure is normal.
2) Suspension problems (my mechanic has replaced the front shockers and spaidels with kabli some months ago still iam not satisfied with result) rear shockers also need repairs or replacement, which is on my top priority
3) oil leak from somewhere and passing through Crank shaft sensor, sometimes car wont start until i plugged out the connector from crank shaft sensor and clean it with a dry cloth (my mechanic told me that it can not be fixed as he needs to open the chamber for this and for that he needs to off load the engine)
4) Gear oil leak ( this is due to a small rubber stopper (gutka) which was removed accidentally from my car) the leakage was stopped by stuffing silicon and some rubber piece. however i need that small rubber stopper, which is not available anywhere.
5) Car runs perfectly on CNG but with low pick up due to this problem my mechanic has done the following things earlier:
Replaced Advancer / emulator
advanced the Timing
Replaced original coils with Honda city coils and made some modification with wiring to fix them
The car was fine for some period but it now again gives low pick up with knocking problem on petrol
Please recommend me a good mechanic, anywhere in khi. i want to make my life easy and get rid of my crappy mechanic.
