Can any one tell me what type of [h=1]Carburetor is this?[/h]I have lancer 1991, 200k+, with piston type carby. While on petrol unless acceletor is badly pressed engine stops.I have tried cleaning from mechanic. It was working 100% ok last week and has simply died. When it was serviced, kechar kachara was present inside it but it was cleaned properly. but even after that no results.
when i start car on petrol, its rpm goes down as if engine will stop i press pedal harder, car gives smoke as if excess prtrol is being burned then if pedal is returned to idle, engine stops. I have tried changing rpm etc. fuel line is clear we have checked that. on idle engine is stopping.
mechanic saying piston carby diff to trace fault blah blah. he suggesting to repolace with 8 valve carby (non piston type with manifold ) as it can fit properly and incrs. fuel eff. asking 7500rs for same,
I doubt that its faulty i think there is some other problem. can any one guide me some good mech in khi?
