Even if you get a cut up wiring harness with correct ECU but a good mechanical engine - you are good to go.
The engine fits easily - the wiring is very easy to do on these cars, the entire harness even made from scratch takes me 1 or 2 days from start to end with correct plugs, looming and placement. (If I can do it - so can you)
Go for it.
