Hello,
So I want help from experts in understanding the difference between these two engine oil grades. Basically I would like to understand which oil is more thicker and which oil has the lowest and highest temp rating. Or simply translate the codes.
0W305W20
Thanks.
0W= Meeting Cold Cranking Viscosity @-35 oC30= Meeting Viscosity range @100C, 9.30 - 12.55W= Meeting Cold Cranking Viscosity @-30 oC20= Meeting Viscosity range @100C, 5.60 - 9.30So 0W-30 is thicker than 5W-20.
0W= Meeting Cold Cranking Viscosity @-35 oC30= Meeting Viscosity range @100C, 9.30 - 12.55W= Meeting Cold Cranking Viscosity @-30 oC20= Meeting Viscosity range @100 0C, 5.60 - 9.30So 0W-30 is thicker than 5W-20 oil.
