Salaam pakwheelers. I am facing an issue. Car in question is axio x 2007 with aftermarket projector lamps. Left side hid flickers for a second and then turns off. Tried blaster on my another car and it works. Bulb life is over or what ? Thankss.
Bulb is at faultHad such issue few time with HIDz Its better to check the bulb few minutes when getting it installedHad a hid set in fogs of my old vitz and had no issue for 2 years but had to change the headlight hid bulb few times due to faulty bulbs
Sent from my iPhone using Tapatalk
What to make sure when buying new bulb. As it works like a charm when its installed new. Im facing this issue for first time after a year of installation bulbs
I would say bulbs physical appearance, its output if its fading or if its changing color after few minutes of usage this would indicate that bulb is going to RIP soon
Btw use stock bulbs for your rideI was a big fan of HiDz but its better to use stock for your sake ( halogen housing ) and others
Dont worry bro. I have projectors in my car. Hids dont irritate front coming traffic at all. Thanks for the info.
Solved. Bulb life was over. Got new one. Cheers
