Urgent help required about 2NZ-FE VVTI Probox 1.3
need to know this sensor mark in photo that what sensor is this & working..
awaiting for experts reply..
Regards
this is MAF mass airflow sensor.....it detects flow of air into engine in simple words.
This is evap Purge solenoid Laymen terms. All of the excessive gas fumes in tank are consumed in the engine at higher loads and this valve is responsible to let the fumes through
So what happens if it is disconnected..
Sent from my SM-N900V using PW Forums mobile app
this blue grip thing is MAF sensor.....its hot wire type means directly going to ecu.
Actually its 2 wire was cutted in my uncle's Probox when it comes to me for AC work n car was running without any check engine light.. i just open that connector sold new wire and connect it back..
