anY 1 knowz abt optra's engine i think its efi ??? but lancer is DOHC and sunny iz SOHC which iz better
kisi ko nahi pata ????
DOHC's better. With a DOHC engine u get quicker response as the cams are mounted directly on top of the valves separately for intake & exhaust.In SOHC 1 camshaft for both the valves. No idea about the optra's engine though.
Engine deignation is the Z16XE,Iron block and alloy head 1.6 DOHC 16V inline-4 rated at 108hp @5800 rpm with a torque of 111 lb-ft@4800 rpm. Designed to run on 93 RON. Power/weight ratio: 90.9bhp per tonneTorque to weight: 12.57kgm per tonneFuel System: MPFI
bro optra engine is 1.6 DOHC MPI (E-TECII) 16V is mention on engine cover, quite powerfull engine
hello!sunny is SOHC...:$...where is ur mind man....from 96 Nissan was giving ECCS with Twin Cam 16V engine....and u say that 2005 model is SOHC...:)Nissan lauches Twin cam in mid 90's with ECCS...so newer engine was definately a DOHC....Thanxxx
hey where are u living nissan is DOHC i know cause i own nissan it is ver good car
man whatever iam getting optra for ma selve and i know its powerfull give u 110@5800 max. output, surely its output is more than any other car in this class 1.6.
optra's engine is good but not the best in its class(1.6L).
Roger.Plus its 110hp is moving a heavier car with a curb weight of 1220kg, compared to 1165 for the VTi and 1158kg for the Corolla 1.6, making it the HEAVIEST in its class!
asdasdasd
