i have a coure 2006 model manual. from last day i am facing a problem. i am not able to push the first and second gear. all other gear works fine (3,4,5, Reverse).
i cant understand ur question???what do mean by last day???and secondly i suggest that first and second gears of ur car are not operating smoothly right??if this is ur problem..chk ur clutch settings and gear oil...
maybe your car start turning into automatic version by itself slowly and gradually
lol @ above.
2006... Dealer should cover this under warranty ?
Change your MTF (try other brand) i had 3rd gear grind problem.i switched to other MTF brand's now i have to problem
MTF=Manual Transmission Fluid
MTF=Manual Transmission Fluid ...is this some kinda gear oil??
"i am not able to push the first and second gear"
do u hear grinding sound or u just r unable to place them in their slot ?
thanks all of u.i show my car to some mechanic and he find that after changing the gear oil someone has not close its lid correctly. so it adjust it and now all gears are working fine
yaar mere car ke first aur second gear grind hotey hai when i shiftt..kia saloution hau is ka??
Get your clutch checked, your thrust bearing might be giving away, better to have it fixed then get clutch plate replaced.
