@allguys i am facing a big problem.mere paas charade petrol 1984 model hai.meri car bahir raat ko khari hoti hai kiyon ke mere paas ghar mien garage nahi hai.tu aaj kal sardiyon mien mujhe subah subah car start karne mien problem hoti hai jabke battery new hai or raat ko petrol mien khari karta hoon.lekin tab bhi yahi problem hai.mujhe eik bande ne kaha ke ache wala OIL istamaal karo.so temm me will engine oil should i use.or spark plugs 2-tip ya 4 tip
anyone |
yaar koi to help kar de mien roz dhaka laga kar thak giya hoon.
buy a blanket for your car. it will help you. hot joking. hmm dont buy a blanket but use some old stuff for this purpose.
check the coil from your mechanic may be your car coil is weak in this case because oil dont have to do nothing with the starting and plug kharaab honay say gaari dhakkay say bhi start nahi hoti phir bhi tune up will help always laikin tell mechanic to check the coil
and u can always pour some petrol in the carbourater b4 starting. btw which oil u are using?
waise yaar mujhe apni charade mien konsa oil dalwana chaiya konsa wala behtar rahe ga
aap saanthay ka oil dalwaye woh best rahay gaa
j/k
koi bhi acha branded oil dalwaao
yaar mujhe itna nahi pata oil ka ap plzz khud hi brand bata do.synthetic oil ka
yaar aap shell ya havoline dalwalo baaqi allah sab theek karay gaa
use cng to start, thickest oil and 2 tip plug
use new NGKR spark plug codeBKR6EY11,coil check karo,starter needs cleaning and use 20w50 engine oil from ny brand eg shel,havoline,quartz
synthetic oil say app kay engine ka hazma kharab ho sakta hai.
synthetic oils are expensive but worth it. in your car they can go upto 10k kms if ur car is not consuming oil.
