Bhai Thats what CNG wala told me when i was there to get CNG installed in a civic.. he told me that theres no need to install advancer as distributor works same as advancer... N if i
ll get an advancer then itll advance the timing so much that i
ll ended up having bad average or low pick..
M not that much into cng.. Dont know whether heve lied to me or not.. But i
ve seen many civics around doin perfectly fyn without an advancer.. becoz they r having distributors....! N as far as ur Info. Electronic distributor n CNG advancer works same.. THey can set the timings n other settings On petrol as well as on cng too..!
A distributor is a device in the ignition system of an internal combustion engine that routes high voltage from the ignition coil to the spark plugs in the correct firing order.
