Assalam o aleekumi am buying I know its accidentedHow can i check its Engine Perfomance that how can i check its mechanical performance??
there is a lengthy process.. if its a total loss, then u should see the engine, gearbox damages. plus the drive and compare it with the same model non accidented vehicle. check its wiring too. else show the vehicle or post its pics. btw unless or until u r getting a very good deal... DON'T GO AFTER IT
I buy these kinds of cars all day long......so its been fixed ? what year ? what kind ? and where it was hit?
As said by takko, unless you are getting a very good deal, don't go for it.
Apart from engine, the main problem normally occurs in the body as the car will start vibrating and making terrible noises if not fixed properly
