Hi,
I had same problem. You can also check, may that is the cause.
It seems to me that fuel pump was not working properly, the actual cause of problem is the fuel pump connector get lose during drive even some time on stall. Closely look at the both connectors one the pump and the connecting cable, it may contain rust or carbon or slight broken.
Start your car and listen to the fuel pump it generate humming sound and try to diagnose the problem.
If your fuel pump is bad try “used pump” from junk yard, those are original Daewoo fuel pumps & work fine.
God Bless U
