Well If It Already Have 2E
So 1.3L 4EFE is Going to Fit With No Mounting Work As Its Of Same E Series.....!!! Power Is Like 96hp
Whereas If U Want 1.6 Gli's 4AFE.....Its A Series So You Need To Work On Timing Belt Side Mount + Need To Adjust Cross Member Mounts.....!!....Gear Side Mount Will Fit As It Was.....!!!
Beside Mount Works....All Things Are Almost Same.....Power Of 4AFE is around 114hp.....!!
So Now Its On You What You Get.....
I Personally Recommend 4AFE Since Spares Are More In Market + SO Much Torque...
Also Get Manual Tranny As You Can Find 4AFE 5AFE Tranny With No Worries..
4EFE=96hp (E-Series)
5AFE=104hp(A-Series)Needs Mount Works
4AFE=114hp(A-Series)Needs Mount Works
