the whole bottle which consists of 400ml is enuff 2 treat 3-6lit of oil!just pour the bottle in n let the car idle it causes no damage to oil seals or nything n neither does the car begin giving off smoke frm the exhaust!
advantage yeh hai keh ...
[highlight]Cleans the inside of your engine oil circuit by removing carbon, sludge and varnish residues
Keeps new engine oil cleaner for longer
Neutralises harmful engine acids, prolonging engine life
Increases engine performance
Improves fuel consumption
Reduces exhaust emissions
btw its compatible with all mineral and synthetic based engine oils
here are more advantages:
An agent to thin old oil, breaking down sludge and particle build up to ensure maximum drainage.
A detergent to clean away residue and unclog oil ways, galleries and neutralise crankcase acids.
A lubricant, (organic molybolan compound) to protect the engine while the solvents and detergents are cleaning.
Newly developed concentrated agent for dirty engines or old oil
Your advantages:
New oil remains effective and clean longer.
Loosens dirt and sludge deposits inside the engine.
Dirt is effectively removed when used oil is drained
Contains surfactants with a strong detergent action
Your advantage:
Cleans and flushes the entire engine oil circuit
Uses / Areas of Use:
If black sludge is suspected.
If hydraulic tappets chatter.
If the oil change is overdue.
In the event of a loss of compression from sticking piston rings.
For all mineral and synthetic based engine oils.[/highlight]
