hi everyone..em havin sum prob wid cars radiator thing..prob is the cars radiator fan is auto matic but it does not always strt on the middle point ov temperature gauge...it sum tyms strts late n sum tym early..ive cleaned the radiator 3 days back..plus the thing vonnected to carborator area for makin the radiator fan run automatic is also changed but prob is still there...(i use coolant always)any suggestion wt is goin wrong?the temperature goes high tht cause coolant level to decrease in the coolant bottle..help me guys..waitin..
PEACE
confusin
you havent specified what car you have,what model,mileage????
and you expect a answer ???????????/really confusing yar
you'll have to be lil' more specific than that(Y)
Which car you got?
Look like a auto fan switch problem.
Car ???
If the overheating problem does not go with the cleaning of raditor, new coolant and direct fan, the culprit is mostly likey a minor leak in the head gasket. Replace the head gasket and get the heads faced too, it will solve the problem
Seems like a thermostat malfunction to me.
yeah sorry..car is khyber 1999 model83000 km mileaged...no thermostat is installed..n auto switch is also changed..car was overhauled 8 months back..early month i ran it direst n aftr one month ov overhaul it was turned auto matic..gaskits were fully replaced tht time..car never did reach to H region so i dont hink gasket shud hav gone wrong
try to get a better fan switchif not probably the gasket it busted. i had the same problem
Direct Your fan. Simple and effective solution.
The japanese khayber switch casts around 700 Rs. did you install this one or chinese one?
It may be due to loose electical connection or faulty thermostat switch.Also check the fan motor for worn bushes.
vaqascan i ask u ur number.mneed ur help in particular cuz i tink u live near chorr chowk dont u?
Check Tapit and Gaskit from any good machenic and then ask machenic to take out the fan and ask him to clean the carbon inside the fan motor and then see if this resolve ur issue or not....
prob solved
How its solved?
I dont live near chor chowk i live near Airport
But my mechanic is in Chor Chowk near city bakery (Friends autos) so my most week ends are spent there hehe.
yar car was showin wrong temp..sum little part was faulty..replaced it n got it solved..costed 200 mazdori sath
