Results 1 to 3 of 3
Thread: Help: Problems with my Hyundai Santro Club GV 2005
    immad96's Avatar
    May 2008
    28
    1,727
    15 Post(s)
    2 Thread(s)
    Default Help: Problems with my Hyundai Santro Club GV 2005
    Hello everyone, i am from Lahore & own my first ever Hyundai Santro Club GV 2005 Current mileage is around 68000Km. I have some problems with my Car & have to take it to some good Hyundai Santro workshop any Pakwheeler can recommend & refer me.
    1. Usually i drive on CNG, whenever i turn on AC my car gives some jerks, sometimes turns off. I went to some guy in Faisal Town, Lahore he said your coils are weak & need to be replaced which will cost 1100/- per Coil (2 Coils).
    2. I think my car consumption is worse. Today i got petrol of 1000/- in Car & it gave me 100km (without AC) in city. How much consumption should it give.
    3. Day before yesterday, I smelled some wire burning smell from Car's indicator Liver, after that Car's lights turning On/Off switch got slightly hard. What could be the problem? After that, when i turn High Beam on, my head lights went off & when i give Dipper, my left light works only .
    4. I noticed today Car's windscreen viper doesn't operate at 3rd positon (it does work and 1st & 2nd position). Rear viper does not work as well hanging down.
    5. Today i drove my friend's Santro & felt my Santro's clutch response is different. My Car's clutch reacts slowly while my friend's Santro clutch reacts like bouncing back @ high speed half the way & than slowly to it's original position. What could be the problem with my Clutch?
    6. Which plugs & Engine Oil should i use for it.
    Any one can recommend me any good Workshop & Cheap as well as i will be taking car to some workshop tomorrow. . . Waiting for a quick reply from experts. Can tell on mobile as well it will be quick my number is 0344-4463026 (Immad Javed).
    Thanks.
    http://www.sohcmydohc.com
    immad96's Avatar
    May 2008
    28
    1,727
    15 Post(s)
    2 Thread(s)
    No one want's to help. . . ?
    moonraider's Avatar
    Apr 2008
    36
    401
    ASA. buddy i am no expert but i happen to own one for about 2 years.
    jerks may be due to several reasons, mainly due to current issue what i think, but what i suggest is to replace and check your plug cables with your friend and see if it still jerks.
    do not wash the engine with water
    use stock plugs (normal ones like ngk, they should work fine)
    milage should be aroung 13-14 km per litre, that is what i think, for engine
    oil, use cng engine oil. (may be shell, i use total cng,but i aint no expert)
    clutch may be loose or tight, but it should release completely, it should not
    be like k clutch dba hua ha,if u get what i am saying..
    check the fuses of your car, in cabin and under the hood
    hope this helps, again i am no expert, just want to help
    peace
    best of luck
    NA cultus 06;stock g10 all motor;faulaadi pistons;half blocked air intake;saada air filter;NGK copper plugs;not so Free Flow exhaust & piping;50kg compressed CH3..want more??
