Hello Well MrFurri, I did a lot of research on it as I was also interested in the same model.
CF3 would be a very good choice, parts are easily available, might be a bit expensive compared to Civics and Corollas but thats understood.
Be ready to increase your budget for fuel, the car will give you roughly around 8km/l if you drive carefully
DONOT buy it if you have plans for installing CNG, you will only get around 70km from a 55kg Cylinder and the cng will ruin your transmission.
Try finding a clean one, some Accords have engines changed or transmissions changed, avoid them, or even if you opt for them, make sure to do a background check and ask for some reasoning
But CF3 is a very good car, DrShaggy at Pakwheels has one of the cleanest ones I've come across, if he was lucky enough to find one, so can you
Hope this helped
