However in your case you'll need to countersteer after the 1st 180degrees AND floor the throttle. however i should point out that the rist of your car flipping over are extremely high regardless of the road surface due to the weight transfer during the spin.
read that pal first..... lolz
and secondly if ya wana do a 360 while moving:
Firstly create a certain amount of speed atleast 60kmhr.
Then position the car properly.(line)
Then put the wrist on the corner of the side of the steering as far as ya can.( so it wud lock as much as it can)
then put the hand on hand brake and press the button and pull as hard as u can and drop when the the car rotates 180*.
Then ya have to control the clutch as when ya doin firstly the 180 press the clutch and do and after doing the 180 press the clutch and drop it in 1st gear.
And put the throttle as much as you can and counter steer the car so it wud makes a proper 360 turn...
In a proper moving 360 turn you have to done the above things in proper way.. Or u might get loose the control.
Well i ma self do this in this way and it happens most of the times.
PAKWHEELS.COM dont promote this kind of things. SO PAKWHEELS.com Wont be responsible for your lose.
Thanks you :d
