Hello dear friends
the Pakwheels map will be available here https://www.zeemaps.com/map?group=582005#
If you are looking for some member at certain location/city. you zoom in and see if someone is there.
Lets say you live in Lahore and you need some help from a member in Karachi. Search Map at Karachi and see who is there. Members will be using their PW profile ID. You go back to Pakwheels.com and reach out to that member via PM.
You are making a road trip. Search on the map along your route and meet members on your way or in case you need an emergency help en- route.
You found a car to buy on pakwheels.com. But its in different city. Look for any member who can go and look at for you personally.
You are moving to a new city and need help. Check if any member is there.
You can organize your local meet.
There can be dozen uses for this markers. I found a service. very good and perfect for all of us to remain in touch.
Its very simple. go to this link on your LAPTOP or DESKTOP
1. On right side of your screen. you will see "MAP ACCESS". Click on it.
2. A password/ Key will be asked. enter 123456. Press Unlock
3. On top menu bar. Click Addition.
4. Click Add marker simple.
5. Add Entry will open.
6. Enter your Pakwheel ID (this is must)
7. You can enter location field by entering the direct name of your city like Lahore, Multan/ whatever.
8. The map will try to locate your city. Or
9. You can click on the map link (in blue).
10. A confirmation window will open with OK
11. Zoom into your map at your location.
12. Click on map
13. A red star will appear.
NO NEED TO PINPOINT YOUR ADDRESS/ LOCATION. JUST SELECT ANY CITY LAND MARK. YOUR EXACT LOCATION IS ABSOLUTELY NOT NEEDED.
14. In the Entry Filed window. There is a photo upload option. Upload your avatar what you use on Pakwheels or anything else/ may be your own photo if you want.
15. Click submit
16. A window will open. Click Ok.
17. Press close button to close the Entry window. ( DON?T CLICK SUBMIT AGAIN A DUPLICATE WILL BE CREATED AT SAME LOCATION).
18. You are Done!
19. Thank You.
igating the Map.
1.You can z
oom into any city and see if any member is there.
2.On The top menu bar Click View?Show List- complete details of all members at the map till to date will appear in alphabetical order.
3.Click On any member name and the map will jump to the member location on the map.
4. The marked maps will work on your phone also.
You can search for a member by city/name (PW ID) on the map.
Announcement: Marker on the map
we don't need you to select the exact location. A city center is fine. Like if you are in Lahore. you can can even select a gas station. or a shop or anything. this is a static location on the map. its like your PW profile with city but on the map. in the location field while filling the entry just write the name of the city or click it on the map. As I said we don't need an exact location. Any city land mark is fine.
For example if you live in Peshawar. On the map where peshawer is written click it or you can select runway of the airport, any park, a mosque, any shop, market anything.
