Importants
The parts of your bike, which are 50-50, should be replaced. Don't take any risk.
Wheel alignment must be done.
Change your clutch cable if it is loosey or having one or two wires pricked.
Examine your break shu and if need be change them.
Change engile oil.
Clean the bike properly, then oil it, better to get serviced.
Must go to the mechanic for screw, nut, bolt inspection.
Anything loose can creat a tension for you as well as us.
Despite the chances of getting mechanics on the road, you must be prepared already for the task. Technicians on the road is a bonus and i will guarantee you their work will not satisfy you. So, be careful please.
Also, you should use gloves to protect your hands.
