cost Rs.1,38,00,000/-
2008 Maserati Quattroporte Base Sedan Performance & Efficiency Standard Features
4,244 cc 4.2 liters V 8 front engine with 92.0 mm bore, 79.8 mm stroke, 11.0 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
Premium unleaded fuel 91
Multi-point injection fuel system
23.8 gallon main premium unleaded fuel tank 19.8
Power: 298 kW , 400 HP SAE @ 7,000 rpm; 339 ft lb , 460 Nm @ 4,250 rpm
