Hello all,
I am in gulf and I bought Nissan Sunny 2013 n17,
Its called Nissan Almera also and Engine is HR15DE,
Problem with car is that when car gets hot like driving for half hour then it loose power ... and sometime sometime RPM starts tickling when idle ... I feel gas smell also ... so sometimes I press accelerator rapidly to get more speed. Some people said it is fuel pump and some said injectors and some said ignition coil.
My mind say its ignition coil but I cant check them because they are under manifold.
I connected obd2 bluetooth adaptor to see some data at my android but couldnt get any reading ... ECU shows two addresses 7E8 and 7E9 ... 7E8 shows nothing no response but 7E9 shows only these => ECU name Transmission, RPM, Engine Coolant Temperature, volts, Throttle position relative and position B,
So how can I diagnose coils or fuel pump,
or how can I get readings from ecu for misfire.
Thanks,
