usp100 comes with a 550watt supply for 9500rs...
i bought it without supply for 5500rs.. i already had cooler master 460watt which i bought a long time ago for 2600rs..
regarding the fans.. the usp100 comes with 1 red led 120mm fan in front.
the other fans i got from canada for approx 800rs for 2 coolermaster 120mm blue led fans.
the black fan is a scythe 140mm fan high airflow. also got from canada along with the zalman cpu cooler..
overclocking does NOT reduce system life
HIGH temperature is what reduces system life. in our weather 50-55 is the max that temperatures should go..
every 10 degree increase above operating temperature reduces component life by half..
i am using asus board g33chipset.. and sapphire ati 4830.. i have had this system for long time now.. recently changed the casing only. i built this system over a period of 4 years upgrading twice..
