Hello,
Sorry for any rules breaking and long post as it is my first post at PakWheels.
I need your humble suggestions, experiences and contact details for items purchase/engineer if possible.
Due to nature of my Job I am not able to research in market and unable to visit, so your past experiences will help me a lot. As far as I can see you guys are very helpful and had very good setups.
Ok here we go?
Current setup:
I live in North Karachi, 240 yards 2 floor house. K-Electric 3 phase meter coming to main switch over which is connected to Honda EG6500CXS 5kva Generator self-start with local gas kit. (We mostly run on gas, after petrol start), manual transfer is required and generator start when every electricity went out.
I also have a local made UPS connected to my pc, cordless phone, ADSL modem, 4 x Royal remote control louver fans in each room just in case in night no one want to start generator. Connected to 220 watt Osaka battery. Backup time is more than an hour but fans speed decreased over time when battery draining out, don?t know its batter fault or UPS.
As mentioned I am not always at home so parents need to do the task and due to their age factor it is quite hard for them day by day.
What I am looking for:
1) ATS (which can run with my current setup)
2) Generator auto SUI Gas transfer option from petrol, so no need to transfer manually
3) An Inverter (wires from it will run to each room for 12 x light, 6 x celling fans / 4 x louver fans and 3 x LCD?s ?40, 40, 32?)
4) Battery option for inventor dry/liquid
5) Good Stabilizer, before/after generator/Inverter (do I need one?)
6) Water Tank level indicator and motor auto start.
7) ?Option/Future? Solar Panel setup for Inverter and UPS battery charge. Possible more items
8) Most IMP: A good educated electrician to do proper wiring and setup.
By above I am looking for a good solid ATS panel which can start my generator and after generator started gas option kick in and convert generator on gas (by using # 2) also maintain the gas pressure as you guys know that when everyone start their generator gas pressure decreases.
Inverter, depends on the above requirement, I am looking to connect about 12 tube lights/energy savers, 6 x celling fans or 4 x louvre remote fans (depends on preference, can run any of them) and LCD?s 2 x 40? and 1 x 32?. Of course not all items will be running all of the times but for sure 6 x fans, 4 x lights and 1 x LCD will be running most of the times. 1 24 CU? fridge will be plus point if we can run on it before generator kick in.
UPS will use for PC, ADSL Model, Cordless and few small mobile chargers. Will remove louvre fans from it.
My generator is around 2 years old, well maintained, purchased new and it is powerful enough to run all required items, even water pump and item with other lights switch off. So I believe it will bear all load with ATS and auto GAS transfer option.
About water tank auto filling option. I saw few post and options but we far as I heard they are fail products??? Am I wrong or misguided? Looking for a solid product as well which works without issue.
I hope I am not asking too much and all the required items are already in market.
So kindly suggest/reply above asked questions with details and contact/purchase details if possible.
PS: I am looking for one off installations so I believe little bit + - in amount will be not an issue. My thinking is buy once instead of changing/replacing every 2nd month.
Thank you and hope to get informative replies.
Thanks
Future Projects: (thinking)
3 to 5 kva Solar Panel Setup
Central Cooling instead of 3 x 1.5 ton AC?s
IP CCTV setup and home electricity automation (control via iPad/smart phone)
