Yesterday I inserted Zong 4G sim in my I9505 but there was no option for LTE. What to do guys?
http://smokeys.wordpress.com/2014/04/06/how-to-enable-lte4g-on-samsung-galaxy-note-3-sm-n9005/
Follow this guide. I had dame problem in my note 3. Fixed by using above method.
Your phone must be rooted
lte option in network mode
you can see LTE with signal ratio
As you can see above posted screenshots of mine ,i am using 4g lte in my zong in samsung i9506. i guess the same should be said right with i9505 . almost same hardware except upgraded snapdrogon processor. at first i was unable to find this LTE/WCDMA/GSM option in network, then i have to delete this persist.radio.lteon file i guess so by using ES file explorer but with root excess and then it came up right away.
You have to change the value in file from false to true.
Whenever I put back some other sim like telenor 3g then wen I again put back zong sim the 4g lte optiin vanishes.
I have to modify the file each time I change sims. Cant this be permanently changed
https://www.pakwheels.com/forums/showthread.php?p=4578018
Read post 94,95 and 96.
naaah, i just deleted it....
delete the file, may be then you can stay active with LTE/WCdMA/GSM option
Solution for this already discussed here. Post 94, 95 and 96.
https://www.pakwheels.com/forums/showthread.php?p=4578017
