how to activate gps in n95.
i think you should consult a company that provides gps facility first..
gps is free to air, this means you dont need any kind of provider or anything. but keep in mind that gps gives you your coordinates in lat, long and your elevation, any software that navigates with help of that data can and can not be free of charge
@haris _13891.download and instal nokia beta map 2 becoz it has setalite map for pakistan2.active gprs on ur set3.open map application open the slide change map mode to satelite4.go to in a open place turn the face of mobile towards he skyNOTE keep the slide open5.it take atlest 40 sec to connect with seteliteonly work in open placesits free but gprs use ke charge hongesee this my position
its very easyand simple
Does the GPS in cell phones work the same way as a stand-alone GPS device? Does it have features like "take me home"?
I don't think a stand-alone GPS requires internet/GPRS connection or any subscription charges.
@wingster.. Which hand set are you using ??
ailiahaider
i thing its N95 coz he has mentioned keep the slide open
^^ I thing what you thing is right :d Thanks..
Will try it on my E66...
^^:$think lolz
[highlight][highlight]@Wahaj12
gprs charges r for map streaming yes it have navigation just like ant other gps devicebut doesnt work in pakistan here u can use this only as positioning device [/highlight][/highlight]
@wingster: that is so un-cool.
in remote locations where u r most likely to use the GPS, u won't have access to mobile networks.
Does this GPS thing work in sony ericssion??if so which models??
@ imtishalonly work on those set which has- Built-in GPS receiver- A-GPS functionas far as i know in SE there is only 1 set which has this functionSE C905
