Results 1 to 11 of 11
Like Tree5Likes
  • 4 Post By Xulfiqar
  • 1 Post By margallar
Thread: Battery Replacement Issue - Daihatsu Move 2013
    ahmedsoofi's Avatar
    Jan 2015
    Default Battery Replacement Issue - Daihatsu Move 2013
    I have changed battery of my Move Custom X 2013 Model. After changing the battery, eco-idle system and radar has stopped working. Also, the auto power window mode is not working either.
    Has anyone experienced such an issue before?
    Please advise. Thank you
    vickybhai's Avatar
    Aug 2005
    26
    2,448
    38 Post(s)
    IS the new battery of same specifications as the one installed earlier???
    1)Suzuki Mehran has changed its shape 2)Fake parts drive me nuts
    3)https://www.facebook.com/RoyaleEM
    khan-uk's Avatar
    Jun 2016
    Solution
    Dear i want to know i have an IR sensor in my toyota raum.
    whats the function of This sensor please clarify me about it.
    ahmedsoofi's Avatar
    Jan 2015
    It is always the best option to keep the engine whilst changing the battery. Otherwise, with my car all systems got activated after 24 hours. I guess the systems took its time to be re-charged and re-activated. Thanks
    ahmedsoofi's Avatar
    Jan 2015
    You will have to be more specific about the Sensor. Upload images if you can so we get to know better. Thanks
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by ahmedsoofi View Post
    keep engine running while changing the battery? (the worst possible advice given in the history of automobiles)
    the way to replace a battery on a car which has a lot of memory features is to use either a set of jumper cables or a starter pack and put that somewhere other than the battery posts - e.g. the jumping ports (if provided) or the starter or alternator heavy lug.
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    if i were running a shop. I would use a motorcycle battery, with a thimble on positive and a crocodile clip on the negative (attach to engine or body). easy peasy small size and quick charge
    if you ask a local electrician to test the alternator, he will remove the battery and run the car on full electrical load
    haters gonna hate, potatoes gonna potate
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by margallar View Post
    I used a small 12V CD70 battery - cheap and easy - put it on a trickle charger once a month.
    integrale's Avatar
    Nov 2015
    7
    2 Post(s)
    I'm in the same boat here - changed my battery from the original wet-cell battery to a Hankook MF42B19L sealed maintenance-free, and eco-idle decides to stop working on my 2013 Daihatsu Mira e: S. No idea what's gone wrong, and no mechanic seems to have a solution.
    I read that a certain battery voltage needs to be reached before the eco-idle feature is turned on (presumably the battery is to be fully charged), and so I checked.
    Standby voltage is 12.43v measured directly at the battery terminals with the ignition off.
    With the car idling, it's 14.28v.
    With car idling, air conditioning running, and headlights on full beam, it's 14.02v.
    To my knowledge, these voltages are within spec, and don't indicate a problem with the battery or the alternator.
    The regenerative braking seems to work just fine as well.
    OBD2 registers no fault codes on Torque, and none on X431.
    What I can't get a clear answer on is whether there's an auxiliary battery installed in the car, other than the SLI battery that I've had changed. Some people talk about the existence of some lithium-ion pack installed behind the backseat that I have found no reference of in the manual (which, admittedly, is in Japanese).
    At least that would give me one more thing to diagnose.
    Right now, I have no idea what the hell is going on.
    @Xulfiqar, any thoughts?
    integrale's Avatar
    Nov 2015
    7
    2 Post(s)
    I believe I might have a solution to this.
    1. Close all the windows.
    2. Turn the key to ignition.
    3. Hold down the auto window (usually only the driver-side window) button and let the window roll down all the way, but continue to hold the button for 3-5 seconds after it's rolled down completely.
    4. Now immediately hold the auto window button up to roll the windows up, and let the window close completely, but continue to hold the button up, again for 3-5 seconds after the window closes.
    5. Try and see if the functionality's been restored.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    @margallar @rustam54 whats the catch here mate
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
