Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By The_sky
Thread: Too much engine noise of Probox in higher gears?
    The_sky's Avatar
    May 2011
    Peshawar
    36
    Default Too much engine noise of Probox in higher gears?
    makes much noise on motorway as you press accelerator. i.e. in 3 and 4 gear the engine noise becomes unbearable.
    what could be the reason and solution?, otherwise everything is good..performance, pick etc.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Exclamation
    what is odometer reading - noisy growling engine means power is not going to wheels in smooth conversion. reason ' Clutch wear & tear '
    assuming that you have purchased it in recent past is there any clutch maintenance work done at time of purchase or in near past? NO
    time to replace clutch set (thrust bearing, clutch plate, pressure plate) change transmission oil as well.
    do snap pictures of drained tranmssion oil & replaced clutch parts Please post at your convenience
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    The_sky's Avatar
    May 2011
    Peshawar
    36
    about 1 lakh, transmission oil was changed recently, but no work on clutch plate as everything was good for the last couple of months, but just recently started this problem.
    if its due to only clutch set then its ok i guess it wont be that much expensive right? i was worried about the other engine head etc issues.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    sure not that expensive, just buy from reliable shop so not get cheated. Carefully read this thread completely.
