Yes I Have Seen The STFT And LTFT And O2 Sensor Readings Tooo!!
WIth This Readings ......The STFT SHould Be High Value As Fuel Must Be Added As Its Running LEAN As Per Readings.....!!
The STFT And LTFT Looks Fine But Doesn't Match With O2 Readings Provided Here........
And I Gon't Guess By Looking At Boxes ... 4AGE Is OBD-1 ....!!
I Don't Exactly Know What These Tools Need To Get That STFT And LTFT ..Might Be Some Signal Which We Can Even Use From OBD-1 To Read That....Nothing Fancy Here....!
Understand The Difference When I Say OBD-1 And OBD-II....
The Error Codes And ECU Communication In Both Is Totally Different....!!!
