AOA.
My friend is facing a lot of issues with his Toyota crown 1994 2jzge(distributor) swapped. Originally it was 2400cc model.
- First problem is the Fuel consumption. His car is giving him almost 3-4km/l max. What can be the issue? How much a well maintained 2jzge crown can do in a liter?
2nd issue is his car is not properly idling and turning off on cold start up along with missing problem when car is accelerated from stand still position and when accelerator is pressed on idle position. In short, Car behaves fine once accelerated.
Also car's pick and top speed is not up to the mark.
Another flaw in car which I have discovered upon inspection is that Fans are direct and thermostat valve is removed. Temperature needle stays on C most of the time. Can this be the root cause of this whole problem?
Car is driven nearly 2 lac km's but engine was swapped nearly a year back and hardly 20k driven. @Xulfiqar. Sir waiting for your response.
