Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By VCheng
Thread: 2004 Toyota Prado TX A/C issue
    spiracha78's Avatar
    Apr 2010
    Faisalabad
    38
    13
    Default 2004 Toyota Prado TX A/C issue
    My car is 3400 cc Petrol. When the compressor turns the cooling is great but it seems like it trip before it reaches the appropriate cabin temperature. Secondly, the gap between the compressor turned off and then turning back on is delayed so much that normal or uncooled air starts to come from the went.
    I would appreciate if some one can shed some light on this.
    akash190's Avatar
    Feb 2011
    Kharian
    22
    1,402
    8 Post(s)
    Low gas maybe
    Sent from my ALE-L21 using PW Forums mobile app
    A real driver knows exactly what's in his car.
    YFaruqi's Avatar
    Jun 2013
    18
    139
    5 Post(s)
    Yes.Most probably low gas
    Sent from my iPad using PW Forums
    VCheng's Avatar
    May 2010
    Select City
    25,478
    7
    434 Post(s)
    4 Thread(s)
    Community Votes: 1
    Quote Originally Posted by spiracha78 View Post
    The proper way to check this problem is to measure the low and high side pressures first, and then evacuate the system to see if it holds a vacuum. If the dessicant/dryer/filter is more than ten years old, it should be changed. Only then should the system be recharged with the specified amount of refrigerant and the correct oil. Usually there is a sticker under the hood with this information. Also, checking the shim clearances in the magnetic clutch relay can be a good idea if it is not working properly.
    livenkickin's Avatar
    Aug 2005
    35
    242
    Please get your coompressor checked. I think the magnetic coil of the compressor is weak and needs changing.
    Sent from my SM-N900 using PW Forums mobile app
    spiracha78's Avatar
    Apr 2010
    Faisalabad
    38
    13
    Thank you all for your help. I have gotten the gas checked and it is full. The head pressure was checked as well and it was ok as per Toyota dealer. I will get the shim clearance and magentic coils checked.
    Thank you all for your help. Will update the progress.
