Re purchased water jacket from g10 for 200/- same quality. Clear the part where tstat has to fit. On cleaning, found a cut type fitting space carved inside that piece, cleaned scratched that, then refitted tstat, it fitted well, applied sealant, jane, sealent, upper jacket nd bolted it with care. Left it for 30 mins, refilled radiator with water, checked for leakage, which wasnt Alhamdulillah. Started the car, nd carefully watched water in radiator, heat needle nd,left engine start. water was cold till 10-15 mins inradiator, while needle was showing its getting hot.... nd then all of a sudden tstat worked nd water of radiator got hot. Ist test successfull.
Disconnected fan, conneted thermo switch with fan. Restarted the engine. Fan wasnt working. Water was hot. After a while it got a lot hot nd seems like near to boil nd fan kicked..... 2nd test success full.
Will do propet wiring for fan nd will attach a led with fan to know when its on nd when its not....
Sent from my HUAWEI G610-U20 using PW Forums mobile app
