ok so guys here i will show you how to remove your cultus dash board ,
and for that you have to first remove the speedo meter and steering column and for removing these you can check my previous posts ,,,,,,,,,,,,,,,,,,few things keep in mind.................no need to remove dash board inorder to remove the AC blower motor and AC evaportor,,,,,,,,,,,,,,,simple remove the left side and upper bolts of dash board ,,,,,,,,lift is few inches and you can easily remove both these things,,,,,,,,but for removing the heating system you have to remove all ,,,,,,,,,,but i guess it rarelly need to remove the heating system, its first time i remove the heating system of any car , and i remove that just because i have to insulate my car under the dash board,,,,,,,,there is an original insulation behind the dash which is called firewall ,,it protects the cabin from engine heat and sound , but unfortunatelly cheap cars like mehran cultus have low quality insulation all around the car, thats why these cars are never gave soundless drive,,,,,,, any how for insulation i will post later,,,,,,,,,,,,,,,,
one more thing,,,,,,,,,,,,,its not necessary to remove the AC pannel and sound system ,,,,,,as you can see i have not remove ac pannel , but you can remove it and for that see my previous posts ,,,,,,,,,,,,,,but you have to disconect the AC control lever wires ,,,,,,,,,,,there are 3 wires and i have shows in this post how to remove them,,,,,,,,,,,,,,,,,,,,,,there are wire clips on left and right side of dash board , just 4 on left side,,,,,,,,,,,one for the blower motor ,,,,,,,,,,one for the AC thermostat,,,,,,,,,and one fore the AC fan motor resistances,,,,,,,,,,and the forth one is the bigger clip , i have shown that in my post as well , remove all these , total 4 clips on left side,,,,,,,,,,and one the right side there are few clips near the fuse box ,,,,,,,,you can see them,,,,,,,,,,,,,,no problem if you mis some ,,,,,,,,,,,you can see all wire clips/connections once the dash board started leaving its place, ,,,,,,,,,,,,so remove all you find ,,,,,,,,,,,
best of luck
