well many thanks ,,,,,,,,,,,,luckily i find the SP10 oil ,,,,,,but its chinese made and i guess the oil inside the can is same as that on ND8,,,,,,,,,,,,,,,well i guess the quantity of oil is not listed on any comp,,,,,,,,,,,,,,you remember i write in my previous posts that the label on pajero mino comp says that it need 100cc oil,,,,,,,,,,,at that time i assume that the quantity of oil is written in volume and not in ml ,,,,,,,,,,,,,but i am wrong ,,,,,,,,,,,,that cc is not the quantity of oil,,,,,,,,,,,,,,,,its the cylider capacity of compressor ,,,,,,,,,,,the same as we have in car engines,,,,,,,,,,,,i also find that the sanden comp whose pic i post above is also of 100cc,,,,,,,,,,,means that the pajero mino comp is 100% compatible with the cultus ac system ,,,,,,,,,,,,,,,,,,,,,another thing is the low and high side pressure of compressors,,,,,,,,,,,,,,well i came to know that all compressor have same low and high side pressures , i.e high side is 3.53 Mps and low side is 1.67Mpa ,,,,,,,,,,,,,,,the only thing which makes them different from each other is the inner cylinder volume ,,,,,,,,,,,and also this makes than varry from system to system ,,,,,,,,,,,,,bigger systems with bigger conderncer and evaporator need more cc comp , ,,,,,,,luckily the one i chose (pajeo mini) in my 06 cultus is really 100% compatiable with the cultus system as both are of 100cc,,,,,,,,,,,,,,,,,,,,,so how can we find the quantity of oil,,,,,,,,,,,,well for that the general thumb rule will work 100%,,,,,,,,,,,,,because the oil will not have to stay in the comp ,,,,,,,,,,it will circulate along with the gas,,,,,,,,,,,,,,,so the quantity of oil depends on the quanity of gas which further linked with the size of system,,,,,,,,,,,,,,,acording to my calculations cultus system need 100ml of oil regrading if you completelly drain the comp,,,,,,,,,,,,system need 450gm of refregrant,,,,,,,,,,convert it into pound and we get 0.99 pound,,,,,,,,,,,,,,and acording to the rule we have to add 3-1.5 ounce of oil per pound,,,,,,,,,,,mean we need 3-3.5 ounce of oil,,,,,,,,,,,convert it into ml and we get 88 to 103ml oil,,,,,,,,,,,,,,,,
what you say about that ,,,,,,,,,,,,,,,,,
