Hello and Sallam guys
I want to change piston in my D15B vtec P08 . i know the about the Piston sizes and bore stuff , I need to know P08 piston can it be replace wid ZC Piston , I heard from ppl tht u can change it wid ZC piston , as u have to play wid Piston head and valve positions in head, I am not worried about the rings size and bore and valve positions, I am worried about the stroke will ZC piston work in P08 coded block ?? I check the market i didnt find this P08 coded one Piston as importer didnt import yet this P08 coded piston so not avaiblke in Pakistan market. so need help in this any one has an idea or suggestions.
D15B VTEC Piston P08 coded
Bore and Stroke :75,0×84,5 mm
Displacement : 1,493 cc (91.1 cu in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.3:1
Sohc ZC Piston
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Rod Length : 137MM
Rod/Stroke : 1.52
Compression : 9.2:1
