Two of the smaller car companies based in Japan – Daihatsu and Suzuki – haven’t exactly been splurging money with new designs since our original 1999 Engine Epic. Nevertheless, there are some welcome additions to the range that are worth covering – we take you on a tour on everything from 550cc turbo threes to a 2.7-litre V6. We’ll also go over the performance engines made by Isuzu.
Here’s how to decipher the engine codes used by each of these manufacturers...
Daihatsu
HD-EG - 1.6 litre 4-cylinder, SOHC, 16-valve EFI
HD-EP - 1.6 litre 4-cylinder, SOHC, 16-valve EFI
HD-E - 1.6 litre 4-cylinder, SOHC, 16-valve EFI
HE-EG - 1.5 litre 4-cylinder, SOHC, 16-valve EFI
HC-E - 1.3 litre 4-cylinder, SOHC, 16-valve EFI
HC-EJ - 1.3 litre 4-cylinder, SOHC, 16-valve EFI
K3-VET - 1.3 litre 4-cylinder, DOHC, 16-valve EFI turbo
K3-VE2 - 1.3 litre 4-cylinder, DOHC, 16-valve EFI
JB-DET - 660cc 4-cylinder, DOHC, 16-valve EFI turbo
CB60 – 1.0 litre, 3-cylinder, SOHC, 6 valve carburetted turbo
CB70 - 1.0 litre, 3-cylinder, DOHC, 12 valve EFI turbo
EJ-VE – 1.0 litre DOHC, 12 valve EFI
EF-JL – 660cc 3-cylinder, SOHC, 12-valve EFI turbo
EB – 550cc, 3-cylinder, SOHC, 6-valve carburetted turbo
Suzuki
K27A – 2.7 litre V6, DOHC, 24-valve EFI
K25A - 2.5 litre V6, DOHC, 24-valve EFI
H25A - 2.5 litre V6, DOHC, 24-valve EFI
J20A – 2.0 litre 4-cylinder, DOHC, 16-valve EFI
J18A – 1.8 litre 4-cylinder, DOHC, 16-valve EFI
G13B – 1.3 litre 4-cylinder, DOHC, 16-valve EFI
G16A - 1.6 litre 4-cylinder, SOHC, 16-valve EFI
M18A – 1.8 litre 4-cylinder, DOHC, 16-valve EFI
M16A – 1.6 litre 4-cylinder, DOHC, 16-valve EFI
M15A -1.5 litre 4-cylinder, DOHC, 16-valve EFI
M13A – 1.3 litre 4-cylinder, DOHC, 16-valve EFI
K10A – 1.0 litre 4-cylinder, DOHC, 16-valve turbo
K6A – 660cc 3-cylinder, DOHC, 12-valve EFI (turbo and atmo)
F5 – 550cc 3-cylinder, SOHC and DOHC versions, EFI turbo
F6 - 660cc 3-cylinder, SOHC and DOHC versions, EFI turbo
Isuzu
4XE1 – 1.6 litre 4-cylinder, DOHC, 16-valve EFI (turbo and atmo)
4ZC1 – 2.0 litre 4-cylinder, SOHC, 8-valve EFI turbo
G200 – 2.0 litre 4-cylinder, DOHC, 8-valve EFI
G180 – 1.8 litre 4-cylinder, DOHC, 8-valve EFI
