@Bilaltq, thanks do let us know and share pictures after you do your DIY :).
As you can see from the picture of tyre marks of the jeep. The surface is hard enough. If its a softer surface you might need a different approach as the same plane lands at another airport which is tarmac (paved).
You might be right as I never asked the pilot if he changed the tyre pressure before landing. They have to have a mechanism to change it mid air or otherwise change in tyre pressure may not be a good idea.
