4A-GEU/GELU Technical Specifications OEM
4A-GEU
4A-GEU
4A-GELU
4A-GELU
4A-GELU
4A-GLEU
Application
AE86 (84-85)
(AE86 86-87, AW11)
AE92 (88-89)
AE92 (90-91)
AE101 Japan (92-95)
AE111 Japan (96-2000)
General
DOHC Belt
DOHC Belt
DOHC Belt
DOHC Belt
DOHC Belt
DOHC Belt
Valves per Cylinder
5
5
Capacity
1587cc
1587cc
1587cc
1587cc
1587cc
1587cc
Bore x Stroke
81.0 x 77.0
81.0 x 77.0
81.0 x 77.0
81.0 x 77.0
81.0 x 77.0
81.0 x 77.0
Compression Ratio
9.4
9.4
9.4
10.3
10.5
11
Fuel Requirements
87
87
87
92(US) 100(Japan)
100(Japan)
100(Japan)
Chamber Flow
cross flow
cross flow
cross flow
cross flow
cross flow
cross flow
Max power (hp)
130@6600 JIS*
130@6600 JIS*
120 @6600 JIS*
140 @7200 JIS*
160 @7400 JIS*
165 @7800 JIS*
Max torque (kg/cm)
15.2@5200*
15.2@5200*
14.5 @5200*
15.0 @6000*
16.5 @5200*
16.5 @5600*
Dry Weight
123
123
126
Camshaft Lift IN/EX
7.56/7.56
7.56/7.56
7.56/7.56
7.1/7.1
7.97/7.60
8.20/7.60
Cylinder Head Construction
polished port
Piston Pin
18mm
18mm
18mm
20mm
20mm
20mm
Piston Skirt
slit type
slit type
slit type
slit type
solid
solid
Piston Spec
coated
oil points
Connecting Rod Spec
large bolt and nut
large bolt and nut
large bolt and nut
lightened
Crank Pin
40mm
40mm
40mm
42mm
42mm
42mm
Block Spec
reinforced block, oil return nozzle
stiffener boss
non ribbed/lightened
Fuel Metering System
AFM (US) MAF(JP,EUR,AUS)
MAF(JP,EUR,AUS)
AFM
MAF
Injector Size
182cc
182cc
182cc
235cc
295cc
295cc
Injector Impedance
1 Ohm
1 Ohm
2 Ohm
2 Ohm
2 Ohm
2 Ohm
Injector Type
Top Feeder
Top Feeder
Top Feeder
Top Feeder
Side Feed
Side Feed
Fuel Pressure Regulator
2.55kg/cm2
2.55kg/cm2
2.55 kg/cm2
2.9 kg/cm2
2.55 kg/cm2
2.55 kg/cm2
Fuel Pump Capacity
OEM Spark Plug
BCPR5EP11
BCPR5EP11
BCPR5EP11
BKR6EP8
BKR6EP11
BKR6EP11
Misc.
TVIS 8 port
TVIS 8 port
TVIS 8 port
4 port
Indiv. Throttle, VVT
light flywheel VVT
larger cap oil pump
Dual Muffler
Single Muffler
piston cooler
Inner shim lifter
Knock sensor
