Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 134
Like Tree174Likes
Thread: Suzuki GS150 top speed
    shadowless_33's Avatar
    Jan 2010
    Jauharabad
    57
    Question Suzuki GS150 top speed
    what is the top speed of suzuki gs150?
  2. #61
    talhabinomar's Avatar
    May 2011
    26
    2,469
    38 Post(s)
    AOA All Brothers,
    Is there performance of bike increase if we mix Hi Octane with ordinary Petrol?
  3. #62
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by FM3o5 View Post
    lol its obvious GS150 will be faster than junoon, but i am saying i havn't done any modifications in the engine, if i do that i can touch 120 :-) my friend did, all i am saying is i expect a lil more from GS150.
    you didn't get what i am saying.... Even if you do 120Km/h on junoon meter , you can't beat GS150 at 110Km/h.
    I have checked many 120Km/h videos on youtube.....
    If you calculate exactly, you'll come to know that when Junoon at 120Km/h on meter, it is actually at 105Km/h real speed. While GS150 and CG125 when at 110Km/h on meter, real speed is 105Km/h.
  4. #63
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Quote Originally Posted by talhabinomar View Post
    AOA All Brothers,
    No it will not, unless u do some real modification in engine that requires fuel with higher octane rating.
    Exploring Machines is my Passion...
  5. #64
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by imranbhatti View Post
    Let me share my experience,
    Suzuki GS150 top speed -333930
    hmmm, doing 120 at 9K RPM???
    Top gear ratio is 0.913 in stock GS150. That means to achieve "true" 120Km/h , you 'll need to be at 11K RPM.
    probably serious error in speedometer.
    Regarding RPM it is showing relatively less reading coz bike was equiped with 3.50-18 Trail tyre which has difnaely increased final drive ratio. Stock GS150 gives ~110KMPH speed @9000rpm
    Even if it has 3.50 tyre at rear, RPM can't be that much less.
    Stock GS150 will give
    98Km/h speed @9000rpm,
    109Km/h speed @10000RPM,
    120Km/h speed @11000RPM,
    and you are in luck if you achieve 12000 RPM in 5th gear, it will top out at 131Km/h speed
    Quote Originally Posted by vickytulla View Post
    GS 150 hales from a GS family of suzuki bikes and a fine peice of engineering.
    Imran did you redlined every gear before shifting, or did it acchieved smoothly ? I rode my friends GS last week and we had a long lonely smooth road and we tried dragging her, it did achieved this speed but on 11000 RPM ... we were two guys on bike, is that the reason ?
    most probable reason that you got this speed at 11000 RPM is that you had accurate meter. It seems accurate theoratically also.
    That being said, though i have not pushed my bike (GS150) much yet, but i have noticed speedometer error at low speeds which probably means error is gonna be much higher at high speeds.
    Alsons is pretty much crap now a days, even chinese meters have less error than my Junoon's original Alsons meter.
  6. #65
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    Quote Originally Posted by gull_s_777 View Post
    most probable reason that you got this speed at 11000 RPM is that you had accurate meter. It seems accurate theoretically also.
    That is not 120. That is 115. Because Alsons instrument panels are piece of ****, you'll have to minus 5-10 kms.
    So technically that is 110 km/h.
    Which is itself the practical limit of this bike if you calculate the top speed by hand using the below info, and any velocity calculation formulae on the internet:
    * rear tire circumference (via size notation)
    * primary and final drive ratios (reductions)
    * gear ratios of individual
    * chain links and pitch sizes
    * max rpm you can reach (of final gear)
  7. #66
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    Quote Originally Posted by sleepyhead View Post
    * rear tire circumference (via size notation) stock tire is 75/90/18
    TIP: If you increase the circumference, for instance, by adding 100/90/18, you can reach 110 or 115 a bit quicker
  8. #67
    abdul.moeez91's Avatar
    May 2014
    25
    28
    Suzuki GS150 top speed -1448179
  9. #68
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    Quote Originally Posted by abdul.moeez91 View Post
    Torque = ((33000 * horsepower) / (2 * pi * rpm)) * 1.3558 newton-meter
    Yes, but theoretically GS has a higher torque of 10.28 Nm at 9000 rpm, than a CG 125. So it can accelerate a bit quicker.
    Plus, if you'll keep rev'ing the CG at that speed for more than few minutes, you will be pushing beyond its designed limits.
    It will start screaming
    And the chances are that the CG engine will over-heat.
    Probably that's what you went through
    Hi guys assalam o alaikum
    i have honda cg 125 my bike engine is over heating what should i do for it ? Give me the suggestion plz
  10. #69
    Ansee's Avatar
    Feb 2013
    Rawalpindi
    342
    27 Post(s)
    2 Thread(s)
    I agree with you @gull_s_777.
    My GS had an ALSONS meter and it also did 118-120km/h at 8800-9000 RPM. (Ofcourse the speedometer had an error).
    Once we planned to check my GS' top speed. With head down, the max it could do was 118km/h on GPS. The speedometer was showing 130km/h and the RPM was a little above 11k.
    Suzuki GS150 top speed -1449226
  11. 21-07-2014, 12:26 PM
    Senior PakWheeler
    Reason
    not required here
  12. #70
    jadoon1992_vxlimited's Avatar
    Dec 2008
    24
    3,388
    7
    69 Post(s)
    6 Thread(s)
    Quote Originally Posted by Ansee View Post
    118 km/hr on gps is amazing. but be safe while riding brother
    people need to grow up sometimes and act MATURE !
  13. #71
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    RPM is at 9K :O i doubt it seems to be a faulty meter; though I've heard a lot about it that it achives the full speed of 120km/h, but poor braking, should be DISC Brake to control such high speed
    Main tay Honda ee lay saa'n !!!
  14. #72
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    Quote Originally Posted by khanthegr8 View Post
    At those speeds, even a disk brake will not help in stopping instantly.
    Stopping distance is nearly 110 meters for speed over 80 km/h. For disk brakes, it might be 100 meters.
  15. #73
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    Amazing speed
    my GS can do 105+ on GPS. But i am not sure about 110, may be with head down and stuff
    At 9K RPM, it shows 115Km/h on meter.
  16. #74
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    Amazing speed
    True. Depends on the total mass (including yours as well).
    Plus, using a wider 100/90/18 tire will increase its circumference and will help.
    GS does 0 to 100, in probably 20-30 seconds. Above that, it's gonna take a bit of time or should I say COURAGE cause, breaking from that speed sucks on Pakistani bikes .
  17. #75
    basic's Avatar
    Aug 2005
    Faisalabad
    50
    1,241
    13
    98 Post(s)
    3 Thread(s)
    Days earlier tried hard, 105 km/h max.(no gps) my weight is around 84 kg.
    My son was riding GTO, passed me easily........
    MADE IN WAZIRABAD.............................RUNNING IN FAISALABAD..........
  18. #76
    surplusstock's Avatar
    Jun 2014
    2,301
    39 Post(s)
    3 Thread(s)
    He passed easily but not in the long run same results.
    Quote Originally Posted by basic View Post
  19. #77
    sleepyhead's Avatar
    Jun 2014
    Faisalabad
    147
    2 Post(s)
    Where were you guys driving?
    As far as i know, FSD has no roads with light traffic, to pull off that kind of feat in less than two minute (time required to go beyond 100 km/h).
    You must have tested it at night or on motorway
  20. #78
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Guys i personally know that a biker is a biker becuase of the freedom of ride and we love speedy bikes... but please do it carefully in a controlled environment no matter where but do take all the counter measures before pushing the small machines to limit.
  21. #79
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    You don't use disc brake for "instant" stopping. You use disc brake because of its lesser "response time".
    Stopping from high speeds with a disc brake will be MUCH quicker.
    Riders on the storm ... literally.
  22. #80
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,276
    90 Post(s)
    7 Thread(s)
    could have been opposite wind.
    Few days back i tried to keep a mehran at my tail but it clocked only 100km/h thanks to strong opposing wind.
    Mehran took over in a matter of seconds.
