AoA,
I currently have a Honda CG 125 Deluxe. The rear wheel is a bad design and many puncture shops refuse to make it. I think it is added complexity. Does Suzuki GS 150 also suffer from same problem?
Sent from my SM-J700H using PW Forums mobile app
In Suzuki GS 150 it's almost same as of Honda CD 70. (Almost)
Sent from my D2502 using PW Forums mobile app
Thanks, that is encouraging.
Deluxe rear sprocket is bolted to the wheel hub, i guess that's why it is complex for puncture shops?
Sent from my LG-H815 using Tapatalk
If this is the case then they might have problems with CG classic then it also has its sprocket bolted to the Hub.
Yes, that is correct. It is a bit tricky.
I think I remember you. You are the person who owned a deluxe and switched to GS 150.
Did you do any modifications to GS 150. Rear tyre, Disk brakes etc.
Aside sprocket being directly attached to the rear wheel. The rear wheel also sits in a slot. And chain cover needs to be removed.
Hey! I saw your post regarding GS 150 . Apologize for asking again.
Keep up the good work.
I am also currently owning a Suzuki GS 150 my EX-Ride was a Honda CG 125 Classic...
No need for apologies.....!
https://www.pakwheels.com/forums/showthread.php?p=3882096
Thanks gull sahab I found your thread.
